Sawing and Drying
Subject:
Can I use radiator fans?
9/6/23
Romulus Member
Can I go to the junk yard and get radiator fans that I can connect to my car batteries that are connected to the solar panels ? Do they give enough flow?. I have and old 16 ft box truck that I want to make in to a kiln
11/22/23       #3: Can I use radiator fans? ...
Ninareyes Member
Yes, you can use radiator fans in your solar-powered kiln. Radiator fans are designed to withstand high temperatures and provide adequate airflow, making them suitable for circulating hot air within the kiln.
However, it's important to ensure that the fans you choose are compatible with the voltage output of your solar panels and car batteries. Additionally, you may need to install a fan controller or thermostat to regulate the fan speed and prevent overheating.
