Sawing and Drying
Subject:
Drying 8/4 white oak
1/23/24
Jeff
Website: http://oldschooltimberworks.com
Hi all, I am trying to dry 8//4 white oak in a DH kiln. Slabs were air dried and showed 14% +- on an pinless meter going in to the kiln. I was pulling good water for about three weeks at about 120F. Then no more water was coming out even though the DH was on full time. I let the load run for another three weeks or so still no water and conditions in the kiln were desert dry (I have a weather station in there that reads out temp and RH). I shut the load down and check moisture content, 6-9% readings. I was not comfortable with that short drying so I cut a slab open and found 16-17% inside. Any thoughts on getting thick hardwood slabs dry in a DH kiln. Thanks, jc
1/24/24       #3: Drying 8/4 white oak ...
gary
Something similar happened to me years ago. I was told the lumber was "case hardened" and to introduce moisture back into the kiln. The outside of the lumber had dried out and sealed the moisture in. I poured water onto the concrete floor and let the lumber absorb it and restarted the drying process. It worked.
1/24/24       #4: Drying 8/4 white oak ...
coooloperator
First question you have to ask yourself is: How is the quality of the charge right now? If checking is present, with a low humidity environment you have this late in the cycle, the chances of check closing is unlikely. If the stock went in with checks, did they get worse, stay the same, or close. Once you have a sound handle on your lumber quality, then you can be in a better decision making position.
1/25/24       #5: Drying 8/4 white oak ...
Jeff
Thanks guys, the kiln manual says I can hit the load hard if air dried to =< 20%. I guess not. Gary, how long did you wait before you cycled the load a second time? Mine has been sitting for a few weeks now.
1/25/24       #6: Drying 8/4 white oak ...
gary
A day or two after I added the water.
1/25/24       #7: Drying 8/4 white oak ...
coooloperator
Hi Jeff,
Re-introducing moisture into your loading can work efectively if you can keep the conditions stabilized for a good period of time. What DB temperature are you running at? The reason I ask is because if you bring the heat up or remains up, and the humidity drops as a result, you may see a drying rate loss that is nothing more than the re-introduced moisture exiting the wood. And you're right back where you started. If you bring your wood temperature down, the chance of the water finding it's way back through the shell to the core is greater, and the opportunity for the capilary flow of moisture from your core increases. I think the key word here is "patience". It's a word that many lumber driers have a hard time with.
1/25/24       #8: Drying 8/4 white oak ...
The MW Studio Sponsor - The Millwork Studio
Website: themillworkstudio.com
Hey Jeff -
Tinker with the kiln settings, make sure the air is flowing smoothly, and watch out for any sneaky cracks on the surface. Letting things chill without active drying for a bit might help too.
