Sawing and Drying
I need a very basic sawmill that is relatively inexpensive
2/27/14
Sam
I need to mill a bunch of timber for a house I am building. I have been using an Alaska Saw mill but it is to slow and cumbersome for the amount of board ft. I need to produce.
I only know of 3 players in the sawmill game for prebuild mills, Woodmizer and Norwood which are both to expensive for me and Woodlands - which doesn't do an 8" deep cut I need for the beams I'm making but has a decent price range.
Are there other companies out there I should look at?
2/27/14       #2: I need a very basic sawmill that is ...
Gene Wengert-Wood Doc
I'll bet you could find a used LT 40, which would be ideal and then you could sell it again and recover your investment. Even a used LT 15 would be ok, but would take more labor and be slower. These are WoodMizer machines, but Norwood has some good equipment too.
2/27/14       #3: I need a very basic sawmill that is ...
EC Aumiller Member
Do a "bing" or "google" search for bandsaw mills... you will find a bunch of mills... here are a couple of them...
http://www.hud-son.com/forestry-equipment/portable-sawmills?gclid=CKGp9
Z-z7bwCFXAaOgodhGEAjQ
http://www.baker-online.com/BAND_SAWMILLS_100.aspx?categ
oryid=100
http://www.turnermills.com/index.html
http://www.cookssaw.com/
2/27/14       #4: I need a very basic sawmill that is ...
smiling hill Member
I bought a Burg (burgbandsawmills.com) for the 38" cutting width but you need to get it adjusted right. I slabbed a 3' wide standing dead white oak with the 13 hp Honda.
find the right blade for the species you will be cutting.
I also looked at a Boardwalk if you want one already put together.
3/2/14       #5: I need a very basic sawmill that is ...
Sam
Sawmill exchange
3/3/14       #6: I need a very basic sawmill that is ...
Dave Boyt  Member
Consider that a good, solid sawmill is going to cost more. In your case, the savings in lumber may pay for the mill several times over. I've been well pleased with the quality of the Norwood. Only problem is that people tend to hold on to them, and used machines are hard to come by. As for the idea of selling the mill when you're through with it, once you've run a mill, you will only sell it to get a bigger, better one. But it sounds like you're already on phase 2 of that! Good luck!
3/4/14       #7: I need a very basic sawmill that is ...
Sam
I bought a used mill about 2 yrs ago from an ad on sawmill exchange, the mill was 3 yrs old when I got it and it runs great it's a Log Master LM4 which retails for $40,500 and I got it for less than half price.I have cut a lot of beams up to 25' long for customers building new homes.
View higher quality, full size image (4608 X 3456)
3/4/14       #8: I need a very basic sawmill that is ...
Rod Hays
I had a Turner mill that worked great. Mine had a 10hp electric motor on it that would cut anything easily. The 30'' mill I had would cut boards up to a littlee more then 116'' wide. Also you don't have to add water to the blade when you are cutting . Plus all the parts come mostly from auto stores,so getting replacement parts is easy. The only things I ever needed was guid bearing which are about $1 each and an idler pulley for the belt.
Turner Mills
3/4/14       #9: I need a very basic sawmill that is ...
Rod Hays
That should be 16'',not 116''
3/6/14       #10: I need a very basic sawmill that is ...
AJ Mearns Member
Just remember, you get what you pay for. Cheap mills are slow if your not worried about how long it takes. I have only seen a few mills that would be worth owning. A friend of mine has a Norwood mill, and I have to laugh on how slow it is and all the problems he has had with it. my two Cooks' mills will last a lifetime. I am posting a picture of my portable set up.
View higher quality, full size image (1206 X 377)
3/6/14       #11: I need a very basic sawmill that is ...
AJ Mearns Member
Forgot to tell everyone that it will cut up to 31' long or many logs all at once end to end. The most logs I have had on the mill at once was 8. Very high production.
Be save people!
3/6/14       #12: I need a very basic sawmill that is ...
Dave Boyt  Member
AJ, that's an awesome setup! I'd love to see it in action.
The original poster was asking about building a house and a next step up from an Alaska mill, so I'll stick with my advice on a manual sawmill. I've been very pleased with the Norwood, and it runs well with just one or two people. There are cheaper mills, but none are more solidly built.
3/7/14       #13: I need a very basic sawmill that is ...
Sam
I bought a mill, I'm withholding the brand until I get a chance to play with it first and make my own observations.
Without seeing it in person I went solely off of the data and abilities it could perform to make my final decision.
If my research pays off it should do exactly what I need and then some.
I also was able to find the brand (which I didn't know about) thanks to this forum - so I appreciate that.
3/7/14       #14: I need a very basic sawmill that is ...
Dave Boyt  Member
Sam, awww, have a heart. Seriously, whatever you got, congratulations on the new sawmill! Looking forward to hearing what you got and what you think of it. Wishing you good weather and straight logs.
8/12/24       #16: I need a very basic sawmill that is ...
Blake Evans
Website: https://petersonsawmills.com/
Hey there,
A swingblade like a Peterson Portable Sawmill might be a good option for you. Their JP model is relatively inexpensive, can cut unlimited length with the track extensions, can double cut up to 12" and is very light and portable. Have you looked into any swing blades or only bandsaws?
