Sawing and Drying
solar kiln
2/2/17
al magrum Member
hi can you use a cargo container for a solar kiln ?
thanks
al
2/2/17       #2: solar kiln ...
Gene Wengdsert-WoodDoc
Sure, with a few design modifications to the collector and lots of insulation.
2/2/17       #3: solar kiln ...
al magrum Member
can i use it as a metal box . doing nothing to the outside except painting.
setting up the inside like the Virginia tech solar kiln?
what kind of fans can i use ?
thank you very much for replying so fast.
2/6/17       #6: solar kiln ...
Gene Wengert-WoodDoc
I am not sure what the inside will be like. The walls and floor of the VT kiln are not special, except for insulation and vapor barriers. In your case, any moisture inside could corrode the walls, so at least use weep holes and vents.
Fans depend on number, size, voltage available, etc.
