Sawing and Drying
old house boiler into a kild
3/28/18
Alec Thurn
My dad has an old water boiler he used to heat his house. I'm trying to get an idea of how to turn this into a Kiln. Any thoughts or advise would be great. also is this going to be a fairly good way to dry the wood with reasonable cost?
3/28/18       #2: old house boiler into a kild ...
Gene Wengert-WoodDoc
If you turn your house into a kiln, you would need at least four times bigger boiler. That is because evaporation of water takes a huge amount of energy. Also, we vent a kiln to exhaust the moisture, so cold air comes in and that means more heat. The boiler you have might also have a peak temperature of the water of 150 F, which is rather cool to transfer a lot of heat from the hot coils to the air. To get enough heat, you will need a lots of fin pipe...four times the amount a house has. Basically, your boiler and coils are too small to be practical. For reference, it might take around 5 million BTU to dry 1000 BF.
4/1/18       #3: old house boiler into a kild ...
don lewis
I think Gene thought you were going to make a house into a kiln. I read it that you want to use his old boiler in a kiln. That might be possible for a small kiln. If you can find the nameplate and take a picture of it either send it to me or post it and I can give you a clue. There are probably less expensive and more practical way to start. Let me know what kind or wood you want to dry.
