Sawing and Drying
Wood expansion for frame and panel sided beehives
4/11/18
Rich Grabon
Hi, I am looking to build beehives in April using eastern white pine (that has sat in an outdoor lumberyard). The hives will be permanently housed in an unheated shed near Hartford CT with a seasonal daily avg RH variation of April 58% to Sept 73% (Annual absolute min max of April 44% to Sept 88%). The bees will generally maintain a hive internal temp of 93deg F with normally 50-60% (up to 85% max) RH. To account for expansion, do I use the variation in daily avg which gives 3/32"/ft radial increase or the annual absolute variation which gives 1/4"/ft? I am assuming that variations within 24 hours will not affect MC significantly, and that the daily average is what matters. Is this correct?
4/11/18       #2: Wood expansion for frame and panel ...
Gene Wengert
You are aware the wood only moves across the grain and not lengthwise?
Indeed hourly values have little effect overall. Weekly averages are better and even monthly.
The EMC for various locations has been calculated. These monthly averages do not seem to agree with your daily values of RH, so use monthly. April average 10.8% and September 13.3%. This is a small change indeed.
EMC
4/12/18       #3: Wood expansion for frame and panel ...
Rich Grabon
Thank You. Yes, I am indeed very well aware that movement along the grain is negligible. I suspected that hysteresis would negate rapid changes over the course of a day, but I didn't realize that it could even extend to averaging periods up to a month. I have built many items for indoor use, but I saw contradiction in the numbers that suggested that outdoor movement would be lower.
