Sawing and Drying
Recommendations for solar kiln controls
5/8/18
Carl
I'm getting close to completing a solar kiln project
based on the VT plans for a 1,000 bd/ft 7X14 kiln with
three box fans.
My reading has me thinking that a good fan control
arrangement would have a temperature sensor/switch
that would turn on the fans when the interior kiln
temperature is 20 F degrees above outside/ambient temp.
A second control would include a humidistat that would
prevent the fans from running at all based on a RH
threshold setting.
Would like to hear from others if this control approach
is sound, and if so, sources and/or examples of the
preferred controllers for this set up.
Carl
5/9/18       #3: Recommendations for solar kiln cont ...
Gene Wengert
Your idea about temperature for turning on the fans is indeed good. However, you could also just use a timer, as your experience will indicate how,long after sunrise and after sunset to turn the fans on and off. This is not as perfect but will work well and is so much easier.
When the fans turn on, thehumidity will often be very high as the wood has released moisture. With the fans on, the vents will work and drop the humidity. So, humidity is not a good variable to use for fan control. Humidity might be used for vent control decisions, opening vents slightly when the daytime humidity is too high and closing them slightly when daytime humidity is too low or you are exhausting too much heated air.
5/9/18       #4: Recommendations for solar kiln cont ...
Carl
Thanks, Gene - the keep-it-simple suggestion
makes sense, and is certainly the easy way to
get familiar with how the kiln behaves.
My comment about a humidistat setup had to do
with using the outside RH to trigger and "off" override
for the fans ... for example, on a rainy day,
the timer would have the fans running despite
the elevated outdoor humidity.
But again, getting things up and operational with
a timer is easy, and initially I can just turn the fans
circuit off when the outside humidity is way too high.
I'll just have to remember to turn it back on ;)
5/9/18       #5: Recommendations for solar kiln cont ...
Gene Wengert-WoodDoc
If you heat foggy air by about 25 F, the humidity drops under 30% RH. Less heat does drop the RH less; even 4 degrees is 87% RH. So, outside humidity is not helpful if there is much sun at all
