Sawing and Drying
sawing crotch wood
7/10/18
steve
I've saved some crotches in hicory and elm. they are about a year old. end sealed and not in contact with ground. I'm ready to saw them on my bandmill. is the pith a concern? should I cut so as to keep it out of my finished slices? they range from about 8" to 20" diameter at crotch. Thank You.
7/11/18       #3: sawing crotch wood ...
steve
I should have said that I plan to lay those so that I cut thru the "00", not the "8" as they are lying on the mill. I did a few yesterday, cutting as close as I could to being centered on the pith all the way through. they turned out good, for now... Thank You.
11/9/18       #4: sawing crotch wood ...
DaveM Member
Steve, I love sawing crotch wood as I make a lot of live edge tables. I usually saw the piece with the pith about 3 inches thick. It is a good bet that it will develop a crack or even a sizeable split while drying. After leveling the slab, you can inlay a bow tie or two over the crack to keep it from spreading & fill the crack with resin. It may be the best looking slab of the bunch.
