Sawing and Drying
swaging
2/16/19
Jonathan Cook
I am new to swaging. I understand that you use the curved opening first and slide it one way tap and then the other way and tap, and then use the straight opening and center it and tap. But what if only one side is worn down. Do I slide toward the side I want to spread out or away from it. I have been recutting some cants that twisted. I am just shaving a little off each side and it is wearing the inside of the tooth, but the other side still has good clearance. Thanks
