Sawing and Drying
drying bamboo
3/6/19
Gary Gossling
Is there any info on kiln drying bamboo out there? Couldn't find much on the internet.
3/9/19       #2: drying bamboo ...
DONALD LEWIS
Website: http://kilnadvisors.com
Nice to see your name pop up, Gary. It's been a while since we talked.
Bamboo is grass not wood so there is not much in the wood field that talks about it. I know a few Nyle customers overseas who dried bamboo and generally they dried it as fast as they could with whatever equipment they had. You do want a good equalization so I would keep the EMC near what you want after the first step where water comes out pretty easily. The EMC values seem to work pretty well for Bambee.
3/9/19       #3: drying bamboo ...
Gary
Thanks Don,
The L200s got some miles on them but they keep going with a little coaxing now and then. I knew bamboo was a grass but didn't know if there were any wood schedules even close. I did find a little info and and as you said drying fast seems to be the answer. We are loading both kilns Monday with about 5000 lbs. of green bamboo each. The owner of the bamboo told me his species of bamboo, grown in Mississippi, averages 13.6 lbs. green and 9.3 lbs dry per 10' x 4" diam. on the big end stick. Not as much water in it as I would have guessed. With only 5000 lbs. in the kiln it should dry fast. With the lengths of it the bamboo won't all fit in one load.
3/9/19       #4: drying bamboo ...
DONALD LEWIS
Let us know how it works out. Good Luck. Never heard of people drying domestic bamboo. Interesting
3/16/19       #5: drying bamboo ...
Gene Wengert-Wood Doc
There are certainly 500 species of bamboo, so it is hard to talk specifics without knowing the actual species. Also, with the limited info, the species you have may not be covered. Are you drying the round tubes? Oftentimes, the tubes are cut into strips, flattened and dried and glued into a sheet, so by the time it hits the marketplace, it is dried well enough. Many species do shrink and swell more than wood.
3/18/19       #6: drying bamboo ...
Gary Gossling
Round tubes. Started the DH kiln at 100 degrees and everything seems fine.
4/25/19       #7: drying bamboo ...
Gary Gossling
The bamboo was done 2-3 weeks ago. Finished it off at 130 degrees. We just dead piled it (per the bamboo owners recommendation) in wood racks we made. Some cracked but the owner said it was typical. It put out a lot of water but went well. The owner has used some for his products and said it was working well.
4/26/19       #8: drying bamboo ...
DONALD LEWIS
Thanks. Did anyone ever find out what the exact species was?
4/26/19       #9: drying bamboo ...
gary
Vivax
