Solid Wood Machining
Buss 44 grinder attachment wheel source??
1/13/14
James Member
Website: http://www.ctihospitality.com/
Hello!
My company recently bought a Buss Model 44 planer that came with a grinding attachment. The grinder did not come with any grinding wheels, and I'm wondering if anyone may know where to find one? The machine is equiped with a Newman Quiet Cut cutter head, so it would need to be a diamond wheel. The wheel dimensions are as follows:
Arbor: 1.25"
Wheel diameter: Up to 4.5"
Thanks in advance for any help!
James
1/13/14       #2: Buss 44 grinder attachment wheel so ...
Dave
Woodtech enterprises inc. has them.They have an online site
1/14/14       #3: Buss 44 grinder attachment wheel so ...
Chuck Rankin
Hi James:
Thanks Dave for the referral. We stock these grinding wheels for the Buss in a pink 46 grit wheel. I have 47 pieces on the shelf. Please feel free to contact us for any additional information.
Best Regards,
Chuck Rankin
Wood Tech Enterprises, Inc.
P.O. Box 2226
Fairview, NC 28730 USA
Phone: 828-628-4414
Fax: 828-628-4490
Planer Grinding Wheels
1/14/14       #4: Buss 44 grinder attachment wheel so ...
James Member
Thanks for the response guys!
Chuck, I had seen those wheels on your site, but I don't see any with a 1.25" arbor hole. Also, would the pink wheel work on the carbide Quiet Cut Head?
I found the linked wheel on Ebay, would that work?
Thanks!
http://www.ebay.com/itm/4-X-1-4-PRECISION-D1A1-DIAMOND-GRINDING-WHEEL-150-GRIT-/350442442652?pt=LH_DefaultDomain_0&hash=item5197ff4f9c
1/14/14       #5: Buss 44 grinder attachment wheel so ...
Chuck Rankin
Hi James:
The pink wheel won't work on carbide. Most Buss planers I'm aware of have a 1-1/2" bore, not 1-1/4". I have Made in the U.S.A. Diamond wheels in stock with 1-1/4" bore in a 4" diameter in stock.
It may be best to contact me direct to discuss your needs and make sure of the best wheel for you for the Quiet Cut head.
Regards,
Chuck Rankin
Phone (828) 628-4414
