Solid Wood Machining
basic knowledge required
7/3/14
windowman Member
While producing PVC windows I like to try to replace the typical galvanized steel reinforcements with wooden reinforcements.
In order to do so I need to use some stable lumber or plywood. I need to cut and shape these into some basic forms (mostly rectangular, L or similar shape) to the specific internal dimensions of the PVC profiles we use.
Any recommendations on materials to use and set-up of machinery is appreciated.
I estimate we would need to prepare about 1000 to 2000 linear feed of varios shapes per month. The size of the shapes would vary between about 20x20mm to not larger than about 20 x 50mm.
7/4/14       #2: basic knowledge required ...
Read
Windowman,
I suggest you look at Accoya. We use it for making windows. It is dimensionally stable, virtually rot proof, has a 50 year above ground warranty, and termites don't see it as food.
