Solid Wood Machining
Makita 9 1/4" Circular Saw Serious problem
4/17/15
ccting Member
This circular cannot cut perfectly 90 degree, but with serious distortion of 90 degree. But the degree shown by back and front indicator saying that is is 0 degree.. Help.
If you cut a very thick wood, you can see very easily it is not straight, with huge degree distorted.
4/19/15       #2: Makita 9 1/4" Circular Saw Ser ...
Scott Sober  Member
Website: http://www.cymafurnituredesign.com
You cannot trust the degree gage on the tool, you need to check/verify that the blade is 90 degrees to the sole of the saw with an accurate woodworking square.
4/19/15       #3: Makita 9 1/4" Circular Saw Ser ...
ccting Member
What is the most accurate and most easiest way to check 90 degree and 45 degree cut? Whenever i check with square, it shows 90 degree and it ends with 110 or 80 degree cut. Something wrong with my DIY saw track ?ty
