Solid Wood Machining
Lubrication for Gear Reducer
4/25/17
Woodworker Member
Last month, I build a simple solid wood machine that mimic to power feeder but able to overcome some weak points of power feeder. it utilize a 3HP electric motor with its 1:120 gear reducer.
It is my first time I connect 3ph wire, build table , connect the motor to two rollers and deal with electric motor.
Could anyone tell me on how to maintain a gear reducer? How to check whether it is lubricated? And could I use Toyota Gear Oil ? How frequent I need to change the oil?
Thank you.
