Solid Wood Machining
Oliver 299 planer
11/27/17
Jason Holtz  Member
Website: jholtz.com
I have a late model (1978) Oliver 299. This machine has the Reeves drive pulley for feed speed control. I believe that the moving pulley plate has some wear in its bore, resulting in vibration/squealing. This in turn makes the speed control dial want to migrate. There is a bolt with a piece of rubber hose on it that is supposed to keep this from happening. That bolt sheared off from its threaded hole, and now the machine only wants to feed at the top speed of 60 fpm.
This is used in custom furniture shop, not a lumber yard so that is way to fast. We always run it on the slowest speed which is plenty fast. I got a price of $1100 for replacement pulley from Eagle. Since the speed control is never used, I'm looking into options to ditch the Reeves drive. I could use a fixed diameter pulley as long as it was the right size, or go VFD route for speed control if I really wanted to preserve it. Yes, I can replace the bolt/hose thingee but that won't solve the underlying problem. Anybody have experience with these?
Jason
11/27/17       #2: Oliver 299 planer ...
bobjh Member
I had a similar problem with a Powermatic planer. I removed the Reeves drive and replaced it with a DC motor and gearbox. Much better. You will also get more power to your cutter head. As now it will not be having to power the feed. Bob
11/27/17       #3: Oliver 299 planer ...
Jason Holtz  Member
Website: jholtz.com
My cutterhead is direct drive, so I don't think I change anything there. My problem is feed speed related only,
Your gear motor then was coupled with a chain to the feed works?
11/27/17       #4: Oliver 299 planer ...
Keith Newton
Jason, google variable pitch pulley with your shaft size. They will screw out wide to use the same belt if you need that.
11/27/17       #5: Oliver 299 planer ...
bobjh
Jason, I used a v belt, since the pulley was already there. You can use a chain if you want to. With DC you change speeds with the twist of a knob. Living large. Bob
11/27/17       #6: Oliver 299 planer ...
Jason Holtz  Member
Website: jholtz.com
Thanks Keith,
Looks like that's going to be way less expensive option. Even if I had to have a new shaft machined. If it were only easier to work on this thing. Might have to lift it up and set it on some concrete blocks so I can get under there rather than working through the two tiny access panels.
