Solid Wood Machining
table saw motor slows down
9/18/18
David Member
I have a Powermatic 66 table saw with a 3hp Baldor single phase motor. Sometimes when I am ripping the blade will slow almost to the point of stopping until I slow the feed to a crawl. No smell, no smoke, doesn't trip the breaker. It will do this for a while and then go back to acting normally for a couple weeks, then do it again. (It isn't feeding too fast or a dull blade; this is with a super sharp forrest blade and 4/4 material).
Any thoughts on this? The motor has both a starting and a running capacitor. The starting capacitor has been recently replaced, so I'm thinking maybe the running capacitor?
9/18/18       #2: table saw motor slows down ...
Russ
Dave
I hear this sometimes with molders, it generally is the belt tension, you might want to check that before spending money.
All the best
Russ
9/20/18       #3: table saw motor slows down ...
bill Member
I think Russ's answer is a good suggestion. I would also check all the electrical connections. As you load the motor the amperage will climb, a bad connection will make it climb very high. If your starter is not correct or the fuses are too big it will not trip.
It's easy to check but make sure you check them all. We had a similar problem with a planer and it was poor connection.
9/21/18       #4: table saw motor slows down ...
Make sure the pulley isn't spinning on the shaft. If set screws were loose enough, even a key could fall out.
9/22/18       #6: table saw motor slows down ...
bobjh
After you rule out anything mechanical. Check to see if you have a high resistance connection. Perhaps undersize wire.Is the motor wired for 110V or 220V?
