Solid Wood Machining
Saw blade sharpening
10/31/18
We are a small shop and do all of our own installations as well as a fair amount of finish carpentry.
I’ve used a couple of the Forrest ww2 blades in the shop for many years. We have a very good sharpening company. I have no idea how many times these blades have been sharpened.
I just bought a Freud Thin kerf Fusion blade for our job site saw. I figured we could get decent cuts of all the random things we cut.
These blades are Freuds version of the Forrest blades. They cost less and I wanted a thin kerf.
The blade comes with a pamphlet manual on how to setup the saw. Forrest gives a similar thing. What caught my eye was Freud has directions for sharpening. 1-5 top grind only 6-10, 11-15 top and face.
Who gets a blade sharpened 10-15 times? How many sharpenings do you guys in the bigger shops get out of a single blade.
11/1/18       #2: Saw blade sharpening ...
Matt Krig Member
10-15 sharpenings shouldn't be an issue if the carbides are in good shape. We've used a few sharpening outfits over the years. It should take very little stock removal to sharpen a blade if they are diligent about set up and not just running an old sharpener. Check these guys out, best we've found- http://www.servicegrinding.com/index.php
11/2/18       #3: Saw blade sharpening ...
Jim Member
Yes. We get at least 10 sharpenings out of our blades.
11/14/18       #4: Saw blade sharpening ...
Number of sharpenings depends on how often you do it. Run the carbides till they smoke, and they have to grind off a lot of carbide to bring it to factory specs. Have a regular sharpening regiment, and you can get twice the number of sharpenings.
