Solid Wood Machining
General 25 " Dual Drum Sander
11/6/18
howard
Website: http://woodcontours@gmail.com
Hi All,
I need to replace the switch box on my sander which is around 12 yrs old. I called General and they told me that they sold the parts business to KMS Tools. Called them and got no joy. Any ideas where I might be able to find parts? General told me that they are no longer able to support these machines which I found really shocking. THanks
11/6/18       #2: General 25 " Dual Drum Sander ...
howard
As a follow up is there a way to re wire this by putting a separate variable speed control that would go to the conveyor and a simple direct switch that would just turn the drums on?
11/6/18       #3: General 25 " Dual Drum Sander ...
BH Davis  Member
Howard,
More information is needed in order to help. Model number, motor phase, HP, magnetic or manual starter, photos of motor and switch box, photo of inside of switch box, electrical diagram if there is one etc.
11/9/18       #4: General 25 " Dual Drum Sander ...
howard Member
Hi, THanks for your help, the model is 15250-m1 25" dual drum 3hp sander. It is a manual switch. The model number on the switch box is MS1-090. Thanks for whatever help you can give.
11/14/18       #5: General 25 " Dual Drum Sander ...
You also need to say if the feed motor is dc or ac, and how it is wired now. Sounds like you might want to call in an electrician.
11/16/18       #6: General 25 " Dual Drum Sander ...
I am not sure where you are located, but a lot of the companies that sell electric motors carry all the switches and electrical needs for most woodworking equipment.
