Solid Wood Machining
molder side fence alignment
12/3/18
Gary Member
The left side fences (viewed from infeed) on our 6 head molder are not in alignment with each other. After top head #4 the fence is offset to the right .010". After top head #5 the the fence is offset .015" to the right for a total of .025" offset. These two fences are independent of each other. They are parallel with each other but offset. Is this supposed to be? The fences are doweled into place and not adjustable but we could work around that.
2/6/19       #2: molder side fence alignment ...
Andrew
Website: https://template-services.com
So I'm not sure I understand the questions perfectly. If you are talking about the fences to the "right" when looking down the infeed, then "Yes" these should be parallel and in alignment. The ones to the left are just normally manually adjusted by hand to the work piece. The offset you describe could make it difficult to control the piece on complex setups. Well worth taking the time to fix. If I did not understand the question correctly, please feel free to call. Happy to dig into it with you. 702-641-2020.
-Andrew-
2/6/19       #3: molder side fence alignment ...
Gary
I guess I did word my question incorrectly. I did mean the "right" side fences. Maybe that's why I didn't get any responses. We did align our fences, which were doweled in place. It did solve our problem.
