Solid Wood Machining
Super thin saw blades for Leadermac Moulder
2/28/19
Jeremy
Looking for feedback on using super thin saw blades on a Leadermac moulder to rip
1/8-3/16" wide strips from 4/4 oak. Pro's and cons?
3/1/19       #2: Super thin saw blades for Leadermac ...
Russ
Website: http://www.mr-moulding-knives.com
Jeremy
Super thin saws has great products that are easy to work with.
A couple of things I would suggest you look into is the horsepower requirements the more blades the higher the horsepower required, in general the last bottom motor does not have a lot of power may a 10-15 HP is common, you may need more.
I would look into bed plates that can receive a phenolic resin insert for the saws to cut into, this provides good support of the work piece while splitting.
I would ask about using a hydraulic sleeve for clamping or at least pins in between the saws to keep them from spinning and welding on the shaft of the molder if they encounter unforeseen issues while cutting,(expensive fix)
Last, but certainly no least, is SAFETY, I strongly recommend you invest in an anti-kickback device to protect your people from kickbacks in and around the molder.
Hope that helps
Russ @ MR
3/1/19       #3: Super thin saw blades for Leadermac ...
Jason
Jeremy do you have a 5 or 6 head moulder? If it’s a 5 head you would run your blades on the last bottom and up into a modified pressure shoe. That phenolic resin board Russ mentions is great stuff!
