Solid Wood Machining
Grizzly 24" Drum sander
10/8/19
Brian Member
I am working on a used Grizzly 24" drum sander that is making a very loud harmonic high pitched squeal. I used a dial indicator and the distance from the drum to the belt is only .025 difference from one side to the other. Also the bed under the belt has some flex to it. I am wondering if either of these may have anything to with the noise. I was also wondering about a possible cracked drum.
10/9/19       #2: Grizzly 24" Drum sander ...
bobjh
My first thought would be a bearing.
10/10/19       #3: Grizzly 24" Drum sander ...
nickko
I have a grizzly 24" dual drum sander and it makes a very high pitched squeal at times. I think it has to do with the amount of material you are taking off. Mine doesn't do it all the time but when it does it is very loud. I think it has something to do with the hollow drums also.
Nicko
