Solid Wood Machining
Home built gang ripsaw plans?
10/9/19
RRickards Member
Hi all, I need to make or purchase a small gang saw that can rip strips of 1/2" thick wood down to 7/16" wide. I only need likely 6 blades running. Anyone who has built one or recommendations? Thanks
10/9/19       #2: Home built gang ripsaw plans? ...
Finding a used Woodmaster would be a much better alternative to building from scratch!
https://www.woodmastertools.com/category/planermolders/
10/10/19       #3: Home built gang ripsaw plans? ...
Jared Emery
Another option is to use a spindle shaper and power feeder: stack 7/16" spacers and a set of 6 identical cutters and off you go.
10/16/19       #4: Home built gang ripsaw plans? ...
Molders can also do this operation....
When I read "Home Built Gang Ripsaw" my first response was an image (cartoon-like, much like the brain activity of Homer Simpson) of a guy pinned to the wall by a piercing 2x that kicked back out of the ripsaw.
I have run XL Ripsaws, all the way up to the larger dip chain gang rips like Mereen Johnson. They all kick back. Many can probably kill you if you are not careful. The XL ripsaw was rarely run due to its danger quotient, but when running you could count on it shooting spears back 60' and sticking them into a well-perforated overhead door.
10/29/19       #5: Home built gang ripsaw plans? ...
Buy a woodmaster planer/molder.
