Solid Wood Machining
RE: Double-sided Edger in shop
2/20/20
Tommy
Is there a shop machine with 2 ripping blades that could straighten the edges out on either side of a piece of wood approximately ¾ of an inch or less thick, where the wood is wavy on either edge?
2/20/20       #2: RE: Double-sided Edger in shop ...
Dustin Orth
Short answer is a gang rip saw. Older models are fixed dimensions that are adjustable by spacers on the shaft. Newer models may have options of moveable blades controlled by a computer or manually moveable by a collar on the saw sleeve. Big choice is what is your budget and infrastructure support of a saw this big. Most of these have minimum of 30HP saw motors, typical is 50HP or above. How much material are you processing? I wouldn't even look at one of these unless your doing quite a bit of stuff everyday, can it save you a bunch of time? Yes, but the cost might be more than you want.
2/21/20       #3: RE: Double-sided Edger in shop ...
Cheap option is a Woodmaster thickness planer with the optional rip blades.
Woodmaster Tools Planer/Moulder
