Solid Wood Machining
Bacci oil-pneumatic cylinder rebuild
3/12/20
Chris Member
Website: https://www.hlancasterco.com/
I have attempted to rebuild the cylinders on a 1998 model Bacci MOD. The cylinders are double-acting pneumatic with oil-damped speed control on one stroke. Just finding all the seals was very difficult and took a long time. I do have a factory parts diagram to go by but no rebuild instructions. This is a very complex cylinder with concentric tubes inside the main shaft that make up the oil circuit. I damaged a couple seals figuring out what order to assemble the parts in. Fixed that known issue, but still have something wrong as there is no speed control. Other than that, it works as it should. If any one of the numerous seals in the oil circuit is damaged or not seated correctly, the speed control won't work. It's probably an order-of-assembly thing.
I have all the documentation there is for this machine.
Bacci doesn't rebuild them, but can sell me new ones for $$$.
Anyone have any experience with this or know someone who does?
3/4/24       #2: Bacci oil-pneumatic cylinder rebuil ...
Scott Peterson
Website: http://heartwood.com
Hi- Unsure if you ever got an answer to your question. I cannot answer your question exactly, other than to ask if you were able to bleed all the air out of the cylinder so the oil can do its job. I had trouble from time to time with small air bubbles getting into the circuit, which would cause the table to jerk at the beginning of its stroke. Otherwise, carefully inspect the needle valve which controls the speed of the cylinder for damage or distortion.
I am currently trying to find a replacement spindle for my MOD, and it is looking to me like Bacci is out of business.
