Solid Wood Machining
Direct Drive VS. Belt
4/10/21
gary
A simple question: Which gives you more
torque ? Direct drive or belt drive ? I want to put a larger motor on my direct drive re-saw
but that is getting to be a lot of weight hanging out there. Make a brace to support
a bigger motor or go with a belt drive profile?
4/15/21       #2: Direct Drive VS. Belt ...
Direct drive is limited to the torque of the motor being used, presumably at a fixed RPM.
A belt driven motor can change torque by changing pulley ratios. Of course this will affect RPMs.
