Solid Wood Machining
Variomatic power feed
6/2/21
Kevin Jenness Member
I came across this listing in the local Craigslist. Is anyone familiar with either the powerfeed or shaper? It supposedly came out of a Quebec furniture shop and then a VT millwork outfit. Is the powerfeed an old version of the current Wegoma Variomatic line?
used shaper/powerfeed
6/2/21       #2: Variomatic power feed ...
I don't know anything about the brands but I would take it as a good sign that the wheels on the feeder are new. But the red flags for possible problems are the fence looks like it might not be original to the shaper because of the paint. The guard hood is not hinged so the wholle fence might have to be pulled away to change large cutter heads, and the locking nut arrangement on the spindle looks minimal and maybe a repair but what could go wrong with that?
6/2/21       #3: Variomatic power feed ...
The shaper seems a little sketchy as the brand is obscure, the fence mismatched and the spindle nut odd, although the seller assures me it is a solid running machine. I am more interested in the powerfeed as my current one is only a three wheeler.. It seems someone cut out a section of the guard above the wheels- an easy fix. It looks like it would be easy to tilt as well. I plan to see it in person next week.
6/7/21       #4: Variomatic power feed ...
rich c
That machine must be 40-50 years old. Not something to count on to make money.
6/11/21       #5: Variomatic power feed ...
Bruce H
If it were cheap enough I'd buy it and re-build the machine.
This machine fell out of a truck and was broken so they gave it to me. I took it apart, blasted the castings, repaired the broken part, applied paint and put it back together. Made in the mid 40's, ought to go another fifty years. The air hold down is not original, something I made out of parts I had.
View higher quality, full size image (3278 X 1406)
View higher quality, full size image (1027 X 1802)
