Solid Wood Machining
large-diameter shaper tooling
7/30/21
a.s. Member
i'm looking for large diameter (at least 6", 1.25 bore) shaper cutters for standard tenoning and rabbeting applications. i'm trying to avoid having a stub spindle fabricated and would prefer insert tooling if it's out there. this stuff is hard to find, and the closest i've come is the occasional window sash set with 6" diameter cutters, but even then it's solid carbide rather than inserts. am i dreaming or is this stuff out there somewhere?
7/31/21       #2: large-diameter shaper tooling ...
Charles Schmidt Co.
7/31/21       #3: large-diameter shaper tooling ...
SteveL Member
Dimensions in Tooling is another place
7/31/21       #4: large-diameter shaper tooling ...
david zaret Member
Zuani cutters are great.
8/1/21       #5: large-diameter shaper tooling ...
Hen Bob
Try Total Tooling Technology. Great guys to deal with.
8/2/21       #6: large-diameter shaper tooling ...
Dustin Orth
I'll second the Charles GG Schmidt. I've had them make some custom tooling as well as stock stuff and always been happy.
8/2/21       #7: large-diameter shaper tooling ...
I have used Schmidt for 8" diameter cope discs, brazed. They has a limit of 5000 rpm. I think if you can find aluminum discs with inserts, you will be better off. That 8" plate is one heavy cutter. The aluminum should be able to spin faster. Be sure the vendor knows you will be cutting end grain. The geometry is different.
8/16/21       #9: large-diameter shaper tooling ...
Bruce H
Leitz would be a good supplier for this kind of cutter.
