Solid Wood Machining
Weinig Profimat 23 Moulder - Material drifts off fence
2/20/25
Brandon Member
Hi all,
Im working on setting up a new to me Weinig Profimat 23. The wood drifts off the fence as it moves down by about 3/4 of an inch by the time it exits. I've been testing the feed by not using any cutters or the chip breaker/pressure shoe, and just the rollers. Even while only using the two middle feed rollers the material still drifts. ( See video ). Also the wood is already straight lined.
Any ideas or suggestions is greatly appriciated!
2/21/25       #2: Weinig Profimat 23 Moulder - Materi ...
Dan Schacht
I had this problem once, many years ago.
As it turned out, I had the feed wheels on backwards.
Try turning them around. They are designed to push the lumber towards the fence. If installed backwards, they will push the material away from ther fence.
2/25/25       #3: Weinig Profimat 23 Moulder - Materi ...
Arnold VanDenburgh
Website: http://Ajvwood.com
I think your feed rollers are on correctly. I think the problem is the little tiny fence that works with the reference engraver. Even when the edge jointing guide is set at zero or no cut the right cutter will still remove .018 from The right side This is to remove the little notch that the reference enGraver cuts. Try cutting a little rabbit out of your test piece and then run it through.
2/26/25       #4: Weinig Profimat 23 Moulder - Materi ...
Dustin Orth
One other possibility to check. Make sure the drive wheel spindles are aligned properly with the fence, i prefer about 1 degree or so canted back. Kind of like a power feeder on a shaper.
2/26/25       #5: Weinig Profimat 23 Moulder - Materi ...
B Member
Thanks for the tips guys, much appreciated!
Dustin, any tips for where this adjustment is made for spindle adjustment? I’m not seeing anything.
2/26/25       #6: Weinig Profimat 23 Moulder - Materi ...
Dustin Orth
Each brand is different but look at where the feed spindles mount, look for set screws or something near the mount plates. Brass shims are another option. I have kentwood and leadermac only so not sure on the weinig specifically.
3/12/25       #7: Weinig Profimat 23 Moulder - Materi ...
I will bet lunch it is the right fence. Either the reference engraver fence or the fence just after the right vertical spindle. Back it away from the stock a few thousandths' and runs piece. Kept backing it off until the stock stays tight against the right fence all thru the machine. Try the reference engraver first, then the fence after the right spindle.
If the fence is out just a bit, it will force the wood away and this will accumulate as it goes down the part. Same thing as a jointer with the outfeed just a few thousandths higher than TopCenter of the cutter head.
I am available for lunch about anytime.
5/9/25       #8: Weinig Profimat 23 Moulder - Materi ...
Michael Myers
The casting upright part that holds the feed beam and mates with the back of the machine casting has lost its tolerance integrity. You will only be able to see this while feeding parts.
You should also be experiencing feed problems until parts are fully into the entire machine.
The reason parts are pulling from the fence is due to while feeding. The feed beam being pushed out of parallel due to feed wheel pressure and loss of tolerance integrity. You will notice feed wheel marks are heavier on the fence side of the part. This will push parts away from fence.
Unfortunately this is a Profimat problem. Weinig has fixed this problem on the small powermats with a feed beam lock mechanism which keeps the beam in parallel to bed. Might be a sollution to your problem as well.
