Solid Wood Machining
Stenner bandsaw blades
8/13/25
Mark Elliott
I just recently purchased a VHM 36 Stenner band saw. The only source for blades I've come up with so far is in England. My concern with that is I think shipping will be terribly expensive, so I would like to find a US source if I could.
If anyone knows where I can buy these, that would be very helpful and greatly appreciated.
Mark
8/14/25       #2: Stenner bandsaw blades ...
BH Davis  Member
Is there something special about these blades that precludes you purchasing from the typical US bandsaw blade suppliers?
8/14/25       #3: Stenner bandsaw blades ...
Mark Elliott
BH,
It's a resaw, the blades are 4" wide x 18'4" long with Stellite tips.
I haven't found a source for those.
Mark
8/16/25       #4: Stenner bandsaw blades ...
BH Davis  Member
Makita used to make a resaw bandsaw with a 3" Stellite tipped blade. Maybe digging into that might bring some positive results.
On the other hand will the saw take a 1-1/4" blade. I've had both the Makita saw and other resaws as well. My experience is that the 1-1/4" hook tooth bimetal blade with 3/4" tooth spacing actually does a better job resawing. But then those saws were a lot smaller than yours taking well under 10' long blades.
5/1/26       #5: Stenner bandsaw blades ...
RichQw1rt Member
Website: https://trinityrental.com/
You don’t really need to stick with UK suppliers. Most guys just go with US companies that make custom blades to your specs — it’s pretty standard for saws like Stenner. As long as you know the size and TPI, they can match it easily and usually cheaper than importing
