Solid Wood Machining
Hydrolock moulder heads
10/21/25
tsuther Member
Can someone explain the hydrolock moulder head please. The ones I've seen have 2 grease fittings on both ends of the head. Do you put grease in both of the outside grease fittings or just 1 ? I cant find anything explaining how its setup on a moulder.
10/23/25       #3: Hydrolock moulder heads ...
Jason
Each end should have a grease fitting and a pressure relief fitting. Depending on what spindle you use the head on there will always be fittings exposed.
11/17/25       #4: Hydrolock moulder heads ...
David William  Member
You typically grease both outer fittings, as they service bearings on each end of the head. Add small, even amounts to avoid over-pressurizing. If unsure, check the machine manual or manufacturer’s specs to confirm the exact setup.
11/20/25       #5: Hydrolock moulder heads ...
Troy
You only need to pressurize one fitting, there are channels that run from one side of the head to the other so both sides clamp evenly. These do not lubricate any bearings or moving parts. Its purpose is to provide closer tolerance from grinding to the machine. Considerably better than straight bore heads by a few thousands and virtually necessary if you intend to joint and run high speed. You do need a specialized grease gun capable of 300bar and appropriate grease. You need a safety collar on the shaft that aligns with a couple dimples on the cutterheads which is simply there just in case a head looses pressure (3 times in 30 years) which is rare. To remove the cutter just twist the 3mm Allen and a small amount of grease about the size of a fingernail comes out and unclamps the head.
11/21/25       #6: Hydrolock moulder heads ...
tsuther Member
Thank you all for responding. Yall are awesome!!
