Solid Wood Machining
single sided drum sander
4/17/26
Chris Member
Website: http://northcabinetcompany.com
I am wondering if anyone has successfully utilized a single sided drum sander in a production environment, or if they simply will not stay calibrated enough to use with much through-put?
https://https://www.grizzly.com/products/grizzly-18-2-hp-open-end-variable-speed-drum-sander/g0458zx
4/18/26       #2: single sided drum sander ...
Dustin Orth  Member
Spend the money on a wide belt sander, drum sanders are not good for final sanding. They will leave ripples and your paper doesn't last very long especially when you are wanting production out of it. Time needed to change paper on a drum sander vs a wide belt will make you cry. Like less than a minute to at least 15-20 if you are lucky on the drum sander. I've had drum sanders a long time ago and you couldn't pay me enough to swap out a wide belt for one of those. Spend the money and get something that will make you money, not cause frustration.
4/18/26       #3: single sided drum sander ...
Jon Member
Only thing I can say is, it is a stepping stone to a wide belt. That's the way it worked for me. It was OK, but slow.
4/18/26       #4: single sided drum sander ...
Painfully slow. A less than stellar widebelt is light years ahead of a drum sander
4/21/26       #5: single sided drum sander ...
Chris Member
thanks guys. confirmed my understanding of the limitations of these machines.
5/14/26       #6: single sided drum sander ...
My experience with a 2 head Performax bore out the rule I violated when I bought it.
Any product that uses a common word for a name, but changes the spelling to avoid legal or consumer confusion should not be bought. "Tastee -Gud" is definitely not what it suggests.
Performax is the opposite of performance.
