Solid Wood Machining
Tooling type for making crown on a shaper
5/19/26
SteveL Member
I have always just ordered the crown molding I need but am getting a little tired of lead time issues. I would like the ability to just make in house.
I only make cabinet doors with my shapers using insert heads from DIT, and that is about the limit of my experience with shaper tooling.
I'm wondering what recommendations anyone has for cutterheads for this, type and brand. I usually use 3-1/4" crown so would be aiming for something in that size range. These would be very short runs around 50ft at a time.
Would it be best to have two heads one for profile and one for the back angles?
5/19/26       #2: Tooling type for making crown on a ...
I would think you would be way better off anticipating your needs and stocking mouldings in house. A shaper is not really the correct machine fot the job. A moulder will give you straighter, smoother crown with less tear-out and sanding.
The other option is to find a supplier that keeps stock on hand and will deliver.
5/21/26       #3: Tooling type for making crown on a ...
Jon Member
Years ago I started making molding on a shaper with a corrugated head. We did it for a short time, but ultimately bought a small Shop Fox molder. It works really good for the short runs that we do. Set up is fairly easy and the machine is small so it doesn't use much floor space.
I know we do not make money making molding, but we have the ability to make any species at the quantity we need in a few hours.
5/25/26       #4: Tooling type for making crown on a ...
SteveL Member
Jon, that is exactly what I want the ability to do match the lumber from the same batch as the cabinets for short runs and be able to do it in a couple of hours.
I know this isn't a money maker its just the convenience of it. When I get a job I put in a lumber order and it will come that week, the molding will have to be run and then will be ready in 1-2 weeks but they aren't going to ship a couple of sticks of crown so I either have to drive 1hr and pick it up or wait until the next order.
I've considered a Williams and Hussey or Fox Molder and haven't ruled it out but space is maxed out. I have the Shapers just sitting there. I can see how making a consistent crown on a shaper would much harder than a molder.
5/25/26       #5: Tooling type for making crown on a ...
Dustin Orth  Member
So a few things to think about, have you ever gotten crown that isn't made consistent in width or thickness? A complete PIA to install. A shaper will excel at making both of those a possibility. A williams and hussey, woodmaster or similar molder will make your own stuff fairly easy. You start doing more than a few hundred feet at a time, you'll wish you had a big molder. If space is a real problem, figure out how to put one of these single top head machines in your shop. I would lose a shaper before not having the in house capacity to make my own moldings. One benefit to making your own is that you can make a profile no one else has and use that as a selling point to start getting more higher end jobs. Food for thought.
