Solid Wood Machining
6 head moulder - big ripples
12/9/25
Alan Barr
Hi everyone! Hoping you can help! I’ve been working with a wadkin 6 head moulder since march as a complete novice, with relative success until this morning! The bar is producing big ripples across the top and below every inch or so. Please see photo! I have tried all I can think of but nothing is fixing the issue. Any ideas? Thanks, Alan
4/2/26       #3: 6 head moulder - big ripples ...
Wally Robinett
Those kinds of ripples usually point more to setup or tooling rather than the machine itself. If it suddenly started happening, I’d check knife sharpness, pressure shoes, and feed consistency first. Even slight play or uneven pressure can leave that repeating pattern. Also worth looking at cutterhead balance or if anything shifted recently during adjustment
5/26/26       #4: 6 head moulder - big ripples ...
JamesSmi63 Member
Website: https://puninwine.com/el/collections/cigars
Big ripples like that usually mean something in the feed or pressure setup changed suddenly. I’d check feed rollers, pressure shoes, and knife/head tightness first. If the pattern is consistent, it’s often a roller or feed issue rather than the knives themselves.
Could also be buildup on the rollers or a bearing starting to go bad. Since it was running fine before, I’d lean toward something mechanical loosening up
