Solid Wood Machining
Butfering Widebelt Basics
7/1/26
Philip Haywood Member
We purchased a 2002 Butfering Widebelt C Line 113-C. The machine is hooked up and running but I'm trying to learn the basics. I purchased it used and it has 2 programs on it - one is designated for veneer and the other for solid wood.
Currently, when I select the solid wood program, it actually gives us good results but the thickness calibration seems to be off by 1.8mm. I'm not sure if it's actually off or not. The machine has a removable graphite platen and I think that one program is supposed to use it and the other is not.
Any advice or resources would be appreciated. I do have the original owners manual CD but the operating instructions lack any illustrations. I placed a phone call to Stiles Tech Support and I'm currently waiting on a call back.
Thanks in advance!
7/4/26       #2: Butfering Widebelt Basics ...
As an update, we're making progress with this machine. Stiles tech support was able to send me documents which showed the process for calibrating the thickness. After calibrating the thickness, we have sanded several parts and we're achieving very good results. We did discover the amount of fine dust that we're producing clogs our Dantherm fiilters and it caused a blowout on our collection bags - a HUGE mess! We'll beat the filter bags frequently to prevent this from happening again. In the past, we could go several days without any noticeable problems and I don't think we ever had a collection bag actually blowout. I suspect the sander is producing far finer dust than we have ever dealt with from the saws or router.
I'm still learning about this machine and the best practices. Our current job is a batch of solid white oak frames but in the next couple of weeks we have a veneer project so that will be a new challenge.
7/9/26       #3: Butfering Widebelt Basics ...
Here is a good article about effective sanding with a wide belt
https://woodweb.com/knowledge_base/Ultimate_Primer_on_2_Head_Wide_Belt_San
ders.html
