Veneer
veneering a 45 degree edge
6/7/14
Jstrader
Is it possible to veneer the face of a 1/2 thick panel on a 45 degree angled cut.
The front of this audio receiver has a 45 degree angle on the total face of the unit. didn't know if I could wet the veneer for awhile before applying it. Also didn't know if I would have to use a clear coat to prevent it from cracking at the tight bend later.
6/9/14       #2: veneering a 45 degree edge ...
Craig
Not likely if it's a sharp edge. You could veneer the flat face then veneer the edge in an offcut from the face veneer and match the grain or vice versa. We do this regularly and if done well isn't distinguishable from a single piece of veneer.
6/11/14       #3: veneering a 45 degree edge ...
jstrader
would you do this out of MDF? that's what I usually use in my vacuum press. I could do the front edge in same type of solid wood ( mahogany) but I was thinking it would never be a perfect match.
