Veneer
Plank Veneer
8/11/14
Rick Matlock Member
A customer has requsted me to glue up some panels with 5/16" thick tg x 3" wide
on 1/2" baltic birch ply. The finished panels will be about 20" wide x 40" long
painted. Will be vacuum pressing. What is going to happen over time?
8/13/14       #2: Plank Veneer ...
Rich C.
It's going to cup, or the solid wood is going to crack. Solid wood moves, plywood doesn't. 5/16 thick acts just like 3/4 thick solid wood.
8/17/14       #3: Plank Veneer ...
Kevin Jenness
If the t&g pieces do not get glued together (wax the edges thoroughly) and are applied to both sides of the panel it should work out. I have done several exterior doors with t&g on a ladder frame that are performing well. The vacuum will tend to suck up glue into the stave joints, so don't apply excessive amounts. Cauls and clamps or go bars may be a better choice for pressure here.
8/17/14       #4: Plank Veneer ...
Rick
Thank you guys for the response to the question. I have talked customer into letting me build style an rail panels to allow for movement.
