Veneer
Mottled Anigre and Glue Bleed Through
8/13/15
Howard Member
I just used mottled anigre with regular titebond in the vacuum press and I see there was a fair amount of bleed through. I plan on the usual scraping and light sanding, but I am new to this species - any issues I need to know about given the bleed through?? Thanks for the help, this is a fantastic resource!
8/20/15       #2: Mottled Anigre and Glue Bleed Throu ...
Joel
In my experience with veneer pressing, using yellow glue, excessive bleed through is because of excessive glue or glue that has been thinned. There really is an art gained by experience as to how much glue to put on. I shoot for about a 32nd thick. Works for me.
8/23/15       #3: Mottled Anigre and Glue Bleed Throu ...
Rich
Unless it's a LEED job, I would recommend urea glue, spread 3-5 mils. Should solve your problems.
