Veneer
Veneer Moisture Meter
3/30/17
I have a Delmhorst J2000 moisture.
Can I measure paper back veneer moisture with this meter? If not is there an accurate meter available?
3/30/17       #2: Veneer Moisture Meter ...
John Van Brussel
Website: http://www.veneersystems.com
If it is pinless it will not work as the scan depth is usually 3/4''. So it will be detecting the moisture content in the material below the paperback.
You can grind the pins flat on some of the pin type meters so that you don't damage the veneer.
