Veneer
Pressing Inside Curve Not Working
8/31/17
howard gorman
I am having difficulty pressing an inside curve. Best way to describe the form I'm using is two hills and a valley(12" deep) and moderate radius . It's the valley that is failing. I am using a core of 3/8" wiggle board then two layers of veneer on each face. Unibond 800 at a slow set rate. So far I am not using a platen on the top, just the bag. Appreciate any suggestions you have since this is getting very frustrating and I'm running out of time.
9/1/17       #2: Pressing Inside Curve Not Working ...
Paul Miller
When we do a lay up with an inside curve, we start the lay up by sticking the concave or inside of the curve first and working outward. By starting at one end and working across the lay up, we have had the veneer or laminate pull away from the inside curve.
