Veneer
Laminated wood flooring moisture content
11/26/18
scott
We are making 15mm thick laminated wood flooring. 4mm thick White Oak top layer, 11mm of birch plywood backer. The flooring will often be used over radiant heat.
What is the ideal moisture content MC of the oak stock after cutting the 4mm top layer to avoid cracking of the surface layer in drier climates?
