Veneer
warped veneered table leaf
12/27/18
arod49ar Member
I have a veneered dining room table leaf that has a severe warp. Is there any way to straighten it using heat/moisture without de-laminating the veneer? It dates from 1920 and I'm pretty sure it's hide glue. I'd rather do this than cut it 3/4 the way through on the back and use wedge shaped inserts in the saw kerf.
12/30/18       #2: warped veneered table leaf ...
duster
Can you post a photo?
1/11/19       #3: warped veneered table leaf ...
Arod49ar Member
Thanks for responding. Customer decided not to bother with this leaf - decided tthe other 3 were enough.
