Veneer
Teak Veneer
6/19/20
Andy Schermerhorn Member
Website: http://precisionbuiltusa.com
Just curious what other people are using for glue for teak veneer and if you are wiping the teak veneer down with acetone before applying glue. This would be my first time using teak veneer. I usually use titebond cold press glue and not sure if that is a good idea in this situation. Any suggestions would be greatly appreciated.
6/19/20       #2: Teak Veneer ...
John Van Brussel
Website: http://www.veneersystems.com
Hello Andy,
I would recommend using a UF resin for teak as it is oily and contains silica.
There is no consensus on wiping with acetone prior to gluing. Some say it works while others say it just brings fresh oil to the surface. I would be more inclined to wipe the surface down with a tack cloth or cotton rag.
Veneer Systems Plastic Powder Resin
6/19/20       #3: Teak Veneer ...
I have used Unibond in the past do you have any reason to use the PPR over the unibond?
6/20/20       #4: Teak Veneer ...
Charles Wright  Member
Website: http://www.northcreekwoodworks.com
Cold or hot pressing, Urea resin is great. If you hot press, most crosslinked PVA glues are good too. Test first. I doubt you need to wipe the veneer down. I'm not familliar with the new Unibond etc products, call Franklin.
6/22/20       #5: Teak Veneer ...
To clarify on the glues: Oily woods like teak respond well to solvent based glues - Epoxy, polyurethane, UF resin, etc. The wood does not require wiping with solvents.
Water base glues like aliphatic resin will respond well with dry, non- oily woods. No solvent wipe needed.
9/6/20       #6: Teak Veneer ...
Doug Member
Here in Hawaii we use Titebond3 for everything including Teak. We use alot of 1/8" veneers inc. Teak and have never had a delamination.
