Veneer
Kuper Stitcher
10/18/20
Adam Member
I recently purchased an old Kuper Stitcher and humbly, know little about using one. What will I need to run this machine? I'm looking for advice on thread type, releasing agents, and any other things I may need to properly run this machine. I mainly use 1/42" thick veneer. The machine is a 1970 Kuper FW/J 800. It's a floor model stitcher with a compact footprint. Any advice is most greatly appreciated.
10/19/20       #2: Kuper Stitcher ...
John Van Brussel Member
Website: http://www.veneersystems.com
There are 2 types of heating systems for these machines hot air and standard. The hot air type has an air line connected to the top of the heater tube.
The hot air glue thread is 921LH and the standard heat is 911NH.
The hot air unit requires a long threader to feed the glue thread through the heater tube. The standard heat unit requires a shorter threader (5")
Release agent (trennmittel) is available in 5 kg containers and is diluted with water.
You may or may not need a new heater tube. The hot air unit usually has a curved inlet nozzle and cone shaped outlet nozzle. These are replaceable but sometimes the main tube develops hairline cracks allowing air to escape and reducing the effectiveness of the heater.
There are also replaceable contacts on both heater types.
We can supply all of the above.
Hope this helps.
10/19/20       #3: Kuper Stitcher ...
John,
Thank you for all your help and insight. I was hoping you would see my post and respond. The machine is being shipped to me and I will get a chance to take in it's needs in a few weeks. I'll be in touch.
11/29/20       #4: Kuper Stitcher ...
Adam,
Did you get the stitcher working?
John,
Does the thread and release agent have best before dates on them? Thanks
