Veneer
using a handheld veneer stitcher
2/17/21
Pdub Member
So we just got one of the Kuper handheld stitchers and are trying it out. I've seen some videos where people are moving pretty fast with them. This ain't the case for us. It seems like if we move fast we are getting gaps between the flitches. My guy is blue taping them together on the other side first to get them to stay lined up. Maybe we just need practice. Maybe the rustic oak veneer we're using is a little too wanky. Right now, I'm feeling this way overpriced machine (not the re-sellers fault) may have been a mistake as it doesn't seem to be a whole lot faster than hand taping.
And yes, we have perfect cuts on the flitch edges.
Any advice or tricks anyone can convey?
2/18/21       #2: using a handheld veneer stitcher ...
Pressure. Press the machine down onto the two leaves and the angled wheels will pull the two leaves together right as it is laying thread. Do not tape the joints prior to stitching.
If the thread is not hot enough, it will not stick, or if it is too hot (and you are moving slowly) it can get too hot and let go before it cools. There is a learning curve, but not a steep one.
Daryl K at Vacupress has some videos that can help. We have found the Kuper to be superior to any other way of joining veneers.
2/18/21       #3: using a handheld veneer stitcher ...
Pdub Member
Thanks David. we will keep working at it. Any idea where those videos are? I tried to find them when you mentioned them in a previous post, but can't seem to.
2/21/21       #4: using a handheld veneer stitcher ...
The videos I have are VCR tapes. Once upon a time.....I can't imaginer trying to locate a working VCR player.
You might call Daryl Keil and ask him if he has anything laying around. If nothing else, he may have advice on using the stitcher. He is a woodworker that expanded the idea of atmospheric pressure into a press. Clever.
