Wood NetWork
Subject: Re: oak front door
oak front door
11/12/14
john Member
I am manufacturing an oak semi circular headed front door and frame in the style of a frame, ledged but not braced door with a full thickness (44mm) bottom rail.
There are 5no tongue and grooved boards 20mm thick set in a 15mm deep rebate. Normally I would fix the boards into the rebates and mid rail with nails (unless any one has a better idea), but I am not sure which to use as it is oak and I do not want any staining. The door is to be finished with Osmo UV clear oil.
11/15/14       #2: oak front door ...
I assume you are talking about a frame and panel exterior door with board type panels.
Think of each board as a panel and let it move in its own space. Give the boards a bit of clearance (see the online calculator - Shrinkulator) and then pin them in place with something non-ferrous.
If you are making v-joint T&G, then the gaps can be smaller or nonexistent since the narrow part of the T&G is a crush zone designed to absorb the expansion.
As for the oil finish, make sure the door gets absolutely no rain on it, and little sun. Oil finishes on doors look great, but will not last more than a month or so. An oil finish is not considered a barrier finish, and like it or not, that is what most exterior doors need.
11/15/14       #3: oak front door ...
Shaun McDaniel
Osmo makes great stuff. The oak uv protection oils are great in that they are easy to re-finish... if done a few times a year all you need to do is wash the door and brush on another coat no buffing, sanding, scraping or stripping required. The good thing about it (easy refinishing) is also the bad thing about it since requires constant maintenance.
    Excel Wood Products
