Wood NetWork
Subject: Re: Wet sheetrock drying
7/11/21
Joel
Hi, I have a water damage job and I had a question about wet sheetrock. The roof had a leak and a large area of the kitchen ceiling came down. There are areas behind the cabinets where the rock is soaked through but not to the point where it is losing it's shape/integrity. I would greatly prefer not to replace those areas as it would necessitate taking apart built in cabinets 60's style.
If I leave it alone will it dry to the point where it can accept paint? Any advice appreciated..
7/12/21       #2: Wet sheetrock drying ...
I would be concerned with mould setting in. Would you be liable? Doubly worse if the insulation is wet.
7/12/21       #3: Wet sheetrock drying ...
Joel
Good point Tom. Replacing that area would require pulling all the cabinets and replacing them though.
7/12/21       #4: Wet sheetrock drying ...
BH Davis  Member
I'd think the damaged sheet rock would have swollen and become punky. Probably best to pull it out. Also as mentioned above mold is a real issue in this situation.
    Excel Wood Products
