Wood NetWork
16' American Chestnut Beam
7/10/12
Ken Member
Have found a Castanea dentata beam that is 16' X 14" X 8" that is in good shape. The big issue is transporting it about 100 miles in which I am trying to find a log carrier that can be used behind a truck or cut it into 2 8' sections then connecting it back together, we would cut the type of joint needed if we have to cut it apart. So my question is is there a steel plates with bolts that can be used also? It will be a overhead beam in a project.
7/11/12       #2: 16' American Chestnut Beam ...
ranliker
Surely someone has a 16' enclosed trailer you can roll it into. We roll whole bunks of wood into ours using a 3 " pipe.
7/11/12       #3: 16' American Chestnut Beam ...
ranliker
More thoughts. Also, it wouldn't bother me to put it on a 10' utility trailer, pushing it past the front a couple of feet (watch your turning radius) and let it hang off the back 4' with a red flag. Much easier than cutting it and bolting back together, which I think would seriouly impair its load rating.
    Excel Wood Products
