Subject: Re: Wall Panel Hardware
Wall Panel Hardware
8/4/17
Could someone point me in the direction of a supplier of various types of hardware/clips for mounting wall panels? These are for a bunch of 1/2" thick x 12"w x 36" long dimensional wall tiles. We can groove the edges of the tiles accordingly. Picture is an idea of what we were thinking with screws through the holes into the wall behind.
View higher quality, full size image (1837 X 886)
8/4/17       #2: Wall Panel Hardware ...
Stuart Douglas
Monarch Metal. We use Z-Clips for stuff like this but they make other clips as well.
8/4/17       #3: Wall Panel Hardware ...
Thanks Stuart,
With these tiles being so thin we were looking for an edge grooved holding system. Im not sure we could get any fasteners that we would trust in 1/2" thick materal
8/5/17       #4: Wall Panel Hardware ...
Dan
Check these out. Available from Hafele
http://www.fastmount.com/clip_system
8/6/17       #5: Wall Panel Hardware ...
Jarin Smoker  Member
We recently installed a wall system using Star hangers. They have a variety of different hangers. https://www.starhanger.com/
We used the regular star hanger since we had wood behind the panels. Our panels were about 9/16" thick so we cut the threaded fasteners that come with the star hangers shorter to make it work. They have some animations on there website to show how the parts work.
8/8/17       #6: Wall Panel Hardware ...
vertice Member
PSI Makes wall systems for thin panels in a variety of reveals and edges. Its progressive system so be sure to plan accordingly.
panelspec.com
8/9/17       #7: Wall Panel Hardware ...
Rick W
If you can't find a suitable clip from a commercial source, you could make a clip like the one you show. You could make it from an "H" shaped aluminum extrusion by trimming off the flanges with a table saw, cutting to length, and drilling and countersinking the screw holes.
It might be worth making it if you had a small section of wall to do. If you have a whole building to do, then obviously it would be better to find some commercially available hardware.
