Subject: Re: flip up door stays
flip up door stays
10/16/18
Tony
Guys I have an application where I have to have 3 flip-up doors. The construction is face frame, inset door. I'm looking for hardware advice. Can I use my regular Blum inset hinges, then just add a stay of some type? Is there one you have used that you could recommend? The doors are 21"w x 18" h. Thanks
10/16/18       #2: flip up door stays ...
Chuck
Blum Aventos are really nice but quite a bit more costly than clip hinges and some kind of stay I'm sure.
10/16/18       #3: flip up door stays ...
Edi Silva  Member
Website: silvawoodworking.com
Tony
use Blum HK-XS with Blum inset hinges, we use all the time, works very nice
10/16/18       #4: flip up door stays ...
Larry Schweitzer
Look @ Sugatsune Slu-Elan door hardware. Very nice, also rebranded by Blum. A bit expensive.
10/17/18       #5: flip up door stays ...
I think Aventos are overrated
I would use the ones from Hafele or similiar
10/17/18       #6: flip up door stays ...
Tony
Thanks for the responses! Just what I was looking for.
10/18/18       #7: flip up door stays ...
Matt Krig Member
We've been liking the Salice Wind hinge since seeing it at IWF .
http://www.salice.com/salice/file/public_admin/Wind-USA_Ed02_08-2016.pdf
10/18/18       #8: flip up door stays ...
Matt Calnen
I’ve been using this one from the Richelieu book. It’s not fancy, but you can adjust the friction to the weight of the door so it functions real nice for a wide range of door sizes.
10/20/18       #9: flip up door stays ...
Bruce H
The Blum lift stay is deluxe. About twenty dollars per door, way easy install and we use our normal hinge. doesn't get any easier.
