Subject: Re: Drawer Front Adjusters
2/4/20
MarkB Member
Been reading the archives and the usual google/vendor research wanting to land on a decent (hate to say the best) drawer front adjusting setup. Ive used a few different options and always wind up back with drawer front adjusting screws followed by fixing screws.
Anyone care to share what they like best? I keep looking at the Blum adjusters which would be a good fit for the CNC and am going to order some in and run some mockups.
Thanks for any input.
2/4/20       #2: Drawer Front Adjusters ...
Nathan W Member
Hi Mark,
Are you talking about these little guys? We started usig these a couple years ago. They are fantastic. If you are using a movento or something like that with adjustment built into the drawers you get double the adjustability. Even with an accuride or cheap undermount like a 230 you get plenty of adjustment. We always used to wait to hang front till we got onsite, now with these we do it on the shop floor and never run into an issue.
Blum standard front adjuster
2/4/20       #3: Drawer Front Adjusters ...
MarkB Member
Nathan,
Yeah, I just ordered a batch of them to give them a go. Im sure the double duty on an undermount would be great. These will mostly be on accuride/KV side mounts. Sick of contractors stripping out the standard drawer adjusting screws trying to tweak fronts with an impact instead of a screwdriver.
I moved my screws out dead against the side trying to make it difficult for them to seat an impact driver in the tight corner but they are still doing it with a long phillips bit.
Do you fix the front with standard screws in addition to the Blum? Or you just run the two Blum fasteners and go on?
Thanks.
2/4/20       #4: Drawer Front Adjusters ...
We used to use the Blum adjusters back in the 90’s. They work really well for euro cabinets. Flat doors. We barely do those so we don’t bother. 1/4” holes and the washer head drawer front screws are all we use. 2 on normal height 4 on tall ones. 20 years and no Blum adjusters. If you cnc the holes that saves a ton of time. On most drawers you need to use the adjusters and screws.
2/4/20       #5: Drawer Front Adjusters ...
MarkB Member
Thanks Adam. We are punching much larger than 1/4" holes with 1" and 1 1/8" drawer adjusting screws. It can still be tricky to get good alignment because when the drawer adjusting screw goes in there is no guarantee its in the middle of the hole (even with a spotting point on the back of the front) so you can run out of adjustment range with the fastener hitting the edge of the hole on occasion.
This is why we punch a larger hole (x2) for the adjusting screws then fix the front with 2 more screws. Works fine if the installers take the time (not our crew) but most of the time they dont. Often times the fixing screws wind up in the trash (not our problem).
Im not concerned with having them perfect out of the shop as its up to the install to choose to adjust or not (weve all been at the doctor or dentist where its clear the install crew never gave a rats a&& about door/drawer alignment and Ive seen the same from huge shops in-house install crews that leave doors and drawers looking like Dr, Seuss).
Just looking for a simpler solution in the shop.
2/5/20       #7: Drawer Front Adjusters ...
Nathan W Member
Hi Mark,
Normally we use two adjusters in the shop, we dont install only supply but we advise our customers to use aditional wood screws to lock the front in place after alignment. Also long screws for mounting the handle gets drilled through the front and the drawer box front, adding another level of securing the face after adjustment. Our software adds them in so everything lines up perfectly if the programs are run right. The added machine time to drill a couple extra holes compaired to manually lining up a drawer front is peanuts.
2/7/20       #8: Drawer Front Adjusters ...
We've used those Blum adjusters for years. We add 2 fixing screws. Works well. I'm pretty sure the installers never adjust anything.
2/14/20       #9: Drawer Front Adjusters ...
Scott Markwood
Website: http://www.hafele.com/us
Häfele America Co. offers a couple versions of this type of drawer front adjuster. See page 8.88 of the current "The Complete Häfele" Furniture/Cabinetry Hardware catalog. (See attached)
TCH2017_Drawer.8.88_2.pdf
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
